Obviously something went wrong, but what actually happened?
I dl'd Conky Metro Clock from Deviantart (published 2011). Then I did as instructed:
Extract the files .conkyrc and .conky_start.sh to your home folder.
Run "chmod +x ~/.conky_start.sh" in a Terminal.
Add ~/.conky_start.sh to your Startup Applications.
I can see the widget in the CM list, but it doesn't show on the desktop.
You must have the conky software itself installed, too.
In terminal run:
sudo apt install conky-all
I highly recommend using Conky manager to help you position, edit or move conky objects around:
sudo add-apt-repository ppa:ubuntuhandbook1/conkymanager2
sudo apt update && sudo apt install conky-manager2
Yes, I have it installed. "CM" stands for Conky Manager 2. Sorry for the possibly misleading abbreviation.
Storm
November 4, 2025, 9:04pm
4
Note, it's from 2011 so it might not work as intended. Then you have to edit it in a text editor.
No... I just read too fast, is all...
Have you adjusted the position of the conky, in case it appeared off screen?
Try zeroing it's position.
That's probably why. I think it's better if I find the newest possible one to start learning the code from."
Mudcake
November 4, 2025, 10:03pm
7
I didn't know about that possibility. Let's explore it... And by the way, I have just started learning Zorin/Gnome. I only installed it about a week ago. Before that I was messing with Debian/KDE
Finally, I found the problem—it was one damn missing comma. Now my very first widget is done and working.
