Hello guys,
I am new to Linux and ZorinOS, I need to install Pop_OS auto tiling on ZorinOS, Since I am newbie I faced to a problem when I tried to install it, I used following link for installing and the problem is in the rebuild.sh command line.
You will need to install gnome-tweaks first though.
I notice it was built (Pop!_OS) for Ubuntu 20.04. Zorin is currently based on Ubuntu 18.04 - Zorin 16 will be based on 20.04 but won’t be out till end of this year/early next.
Thank you @swarfendor437
because of this option I switched to Pop_OS for a month, but it slows down my laptop after 3 weeks!
I guess Zorin is the best Option
Well it is a nice option and you can tweak it to your needs. If you want lightness and speed take a look at AntiX 19 or MX-Linux 19 - very minimal on resources which means your notebook will fly! Also take a look at LXQt (the Qt version of what was/is LXDE) - I added it to Zorin Core and still have it if I want to login to that DE for a change:
Actually I tried at least 20 distros and I think ZorinOS is the best Linux distro, My Notebook has 256 GB NVME SSD, with Intel Core i3 8th gen, it should work fine.
Anyway thank you for helping…
