Like i said, im unsure if my CPU gets identefied correctly. Reason is, that in lutris own system information, it tells me that only 2 cores would be there
But in system monitoring it says 4 cores.
What does Zorin now use?
Try either one of these in the terminal:
mpstat
iostat
pidstat
Should tell you the correct number, they do for me.
As does Zorin menu -> Settings -> Details -> About.
It tells me that there are 4 cores, but nowhere is said if it has 8 threads or just 4 …
Use lscpu
Lutris shows 2 physical cores and 4 virtual cores.
Monitoring is showing all 4 virtual cores.
See here for information on cores and hyper-threading.
