This is the correct place to go- However a gtk.css file will not necessarily be placed in that directory unless the user creates one. So, you should have a gtk-3.0 folder in your home ~/.config directory already. Open your File Manager, hit ctrl+h to show hidden files (Those with a . before the name) OR you can select âshow hiddenâ from the drop down menu of âViewâ.
Open .config and scroll down to gtk-3.0, open it and create a new text document named gtk.css.
The reason why this is the route to go: Yes, you certainly can modify an existing theme gtk.css file, but putting your code in an independent file protects your existing gtk.css from mistakes, typoes and changes and allows you fast and easy access to the modifications.
The system gives priority of preference, so when you load a theme, it checks that file first, then your home themes folder ~/.themes, then checks /usr/share/themes.
Hopefully that helps as a quick crash course on the system. Letâs look at modifying your gtk.css file for Scroll bars.
In gtk.css, if you use steppers, the engine calls on the gtk button node. The width of the buttons will be affected by the more general button width, so if you want to isolate the width of scrollbar stepper buttons, you can use the âmin-widthâ and âmin-heightâ
scrollbar {
-GtkScrollbar-has-backward-stepper: true;
-GtkScrollbar-has-forward-stepper: true;
-GtkScrollbar-fixed-slider-length: false; }
For example:
scrollbar.vertical button.down {
-gtk-icon-source: none;
min-width: 8px;
min-height: 8px; }
You can set the icon source to a file if you like. But it is best to qualify ânoneâ in there if you do not specify a file (i.e., donât leave it out entirely), otherwise the engine defaults to the inherited theme that has a qualifier.
The same applies to your scrollbar trough and scrollbar slider. You can also use padding.
scrollbar.vertical slider {
min-height: 92px; }
scrollbar.horizontal slider {
min-width: 92px; }
Hope this helps you get in and modify as needed.
