hey, so my monitor is 1680 by 1050, and zorin os settings page doesnt have that resolution, can somebody help?
Switch to Xorg if you are on Wayland. To do this logout and at login click on your username, then a cogwheal appears at the bottom right corner. There you can switch between both.
Then enter
xrandr
Look if the desired resolution is shown in the list there.
