Here you go > Installing Steam on Zorin = Solved*
STEAM DOCTRINE — ZORIN (APT INSTALL) — STABLE ARCHITECTURE
This document exists because we debugged everything the hard way.
Steam was never the core issue.
Filesystem structure and broken symlinks were.
I. INSTALLATION PRINCIPLES
  1. Install Steam via APT only:
    sudo apt install steam
  2. Do NOT mix:
    - Flatpak Steam
    - Snap Steam
    - Manual tar installs
    - Multiple Steam roots
  3. Steam root should be:
    ~/.steam/debian-installation
    (APT install default)
Do not reinstall Steam to solve library or filesystem problems.
Steam reinstall does NOT fix prefix or mount corruption.
II. DRIVE + NTFS RULES
External drive mount must use correct ownership.
fstab entry example:
UUID=AC34CABA34CA86B4 /media/jon/4TBDATA ntfs-3g uid=1000,gid=1000,umask=0022,windows_names 0 0
Critical:
  • uid=1000
  • gid=1000
  • not mounted as root-only
Verify with:
mount | grep 4TBDATA
If mount shows user_id=0, group_id=0 without uid override,
Steam may fail writing prefixes.
Filesystem permissions always matter more than Steam version.
III. LIBRARY STRUCTURE (CRITICAL)
Working library path:
/media/jon/4TBDATA/SteamLinux
Inside steamapps/ MUST exist:
steamapps/
    common/
    compatdata/
    shadercache/
    downloading/
    workshop/
compatdata must be:
- A REAL DIRECTORY
- Not a symlink
- Not pointing to another home path
- Not pointing to another user
We fixed:
compatdata -> /home/jon/.local/... (dead path)
compatdata_local -> /home/en/... (wrong user)
Broken symlink = Proton cannot create pfx.lock
Broken symlink = Cloud fails
Broken symlink = Game fails to launch
Fix method:
rm steamapps/compatdata
rm steamapps/compatdata_local
mkdir steamapps/compatdata
chmod 777 steamapps/compatdata
After this:
Proton can create prefix.
Cloud initializes.
Sync works.
IV. libraryfolders.vdf RULES
File:
~/.steam/steam/steamapps/libraryfolders.vdf
Must not contain empty entries like:
"1"
That breaks library parsing.
Fix by removing empty blocks.
Steam does NOT require sequential numbering.
Gaps are fine.
Empty entries are not.
V. PROTON ARCHITECTURE
Windows games require:
steamapps/compatdata/<AppID>/
Prefix created on first successful launch.
If game fails before prefix creation:
Cloud will not initialize.
userdata// will not exist.
If prefix corrupt:
Delete ONLY that game's compatdata/ folder.
Relaunch.
Never delete full compatdata unless required.
VI. PROTON GE INSTALL (MANUAL METHOD)
Install GE into:
~/.steam/steam/compatibilitytools.d/
Manual method:
mkdir -p ~/.steam/steam/compatibilitytools.d
Download latest GE-Proton tar.gz
Extract into compatibilitytools.d
Restart Steam
Set per-game:
Properties → Compatibility → Force version → GE-Proton
GE often better for UE5 games like Manor Lords.
VII. CLOUD SYNC ARCHITECTURE
Cloud location:
~/.steam/steam/userdata/<SteamID>/<AppID>/
Cloud errors mean:
Either prefix never created
Or Steam cannot write locally
Or directory missing
Cloud errors are a SYMPTOM.
Prefix or filesystem errors are the CAUSE.
We confirmed:
No userdata/ existed.
Because prefix never built.
Because compatdata symlink was broken.
Once compatdata was fixed:
Prefix created.
userdata folder appeared.
Sync succeeded.
VIII. DEBUG ORDER (THE REAL ONE)
If game fails:
  1. Check compatdata exists and is real directory.
  2. Check libraryfolders.vdf for corruption.
  3. Check mount permissions.
  4. Launch game once.
  5. Confirm compatdata/ appears.
  6. Confirm userdata/ appears.
  7. THEN evaluate Proton version.
Filesystem > Library VDF > Proton > Cloud.
Never reverse that order.
IX. DO NOT DO THIS AGAIN
Do NOT:
  • Create compatdata symlinks
  • Point compatdata to another home path
  • Mix users (/home/en vs /home/jon)
  • Reinstall Steam to solve prefix problems
  • Assume cloud error means Steam is broken
Steam is stable.
Structure is fragile.
X. FINAL PRINCIPLE
When Steam behaves strangely on Linux:
It is almost always:
A path problem.
A mount problem.
Or a broken symlink.
Not Steam.
Not Proton.
Not Cloud.
Stability comes from:
Clean mount
Clean library path
Real compatdata directory
Controlled Proton versions
This system now works.
Do not destabilize it unnecessarily.
The Gaming category is fitting.
But I moved this to Tutorials & Guides as I believe this can be a major reference point many of us can point to.
This is a lengthy post; but I read through it, checking for accuracy.
Simplified - just copy/paste the whole post into your local AI. ask it to guide you thru - simple.
монтування дисків для Steam.
lsblk - знайти правильні диски: sda/sdb/sdc
sudo mkfs.ext4 -F /dev/sda - форматування/монтування диска в Ext4
sudo mkdir /mnt/SteamGames - монтування/створення діректорії SteamGames
sudo blkid - знайти правильний UUID=дисків........
sudo nano /etc/fstab - налаштування, правильного монтування.
в самий низ додати:
UUID=........... /mnt/SteamGames ext4 defaults 0 2
sudo mkdir -p /mnt/SteamGames/SteamLibrary - монтування SteamLibrary.
sudo chown -R admin:admin /mnt/SteamGames - надати права до діректорії
admin:admin - замінити на ваші!!
sudo mount | grep SteamGames - монтування діректорії з правами.
ls /mnt/SteamGames/SteamLibrary - перевірка чи існує діректорія.
sudo chown -R admin:admin /mnt/SteamGames надання прав до діректорії на зміну.
PS: якщо у вас диски ntfs від Win10/11 - дуже рекомендую вимкнути "швидке завантаження у Windows" без цього любі дії з захищеним місцем не можливі!
якщо Windows була підключена на материнські платі у гріздо 2, у вас не вийде підключити цей диск у 1/3/4гніздо, як і інші диски оскільки у них є свої точки монтування!
тільки повне форматування дисків допоможе.
