Wow, it's so containerized and isolated that it can't even see the Wi-Fi, or it just hasn't the permission to connect, but I suppose that you enabled it when you installed it if you could at least reach a settings section. Otherwise I have no idea about why it doesn't work.
Are you booting in Legacy (MBR) and not EFI?
Do you have UFW Firewall enabled?
Do you have dbus-x11 installed?
apt search dbus-x11
Have you tried this suggestion here;
yes i have tried it
help i forgot to answer cause of my o level exams but one of these cmds has rurned of my laptops internet even moblie usb thethering doesnt work
bwt exams in less then 15 days ![]()
Could you clarify?
We need to know more then, about your hardware.
sudo lshw -C network
What drivers are you using?
What commands did you run?
idk 2 many
