How can I adjust corner smoothing in Zorin OS?
Hello, except for system applications, the top corners appear rounded in all applications, but the bottom corners do not, and this bothers me a lot. How can I fix this?
Yeah, this depends if the Program is in GTK3 or GTK4. You can help with the Gnome Extension here.
When You use Zorin 17, take this: Rounded Window Corners - GNOME Shell Extensions
For Zorin 18 take this one: Rounded Window Corners Reborn - GNOME Shell Extensions
It also depends on whether the application was built as window or as notebook stack - the stack will not respect rounded bottom borders, on GTK3 or GTK4.
You can think of Notebook stack as resembling a Pull Down Projector screen.
It is founded upon the header at the top with the space below sizing to accommodate the content.
You cannot fix this using .css styling, since there is no border on the notebook stack to affect.
