Hi, welcome to Zorin OS!
All you need to do is write the same terminal command on the "Command" field. Make sure to point to the correct location where the executable is. For example, if you have the TLauncher.jar in your downloads folder, you would write java -jar /home/tawsif/Downloads/TLauncher.jar. Adjust this path as needed.
