I need to completely disable hardware acceleration for the system. I'm using zorin lite...
thanks!
Create a new file:
sudo nano /etc/X11/xorg.conf.d/disable-gpu.conf
Paste this into it:
Section "Extensions"
Option "GLX" "Disable"
EndSection
Tap ctrl+x to exit, then the y key to say yes to save, then the enter key to save and exit.
Reboot to test.
no xorg.conf.d folder. do i have to create one??
Yes, you must create the file.
the folder xorg.conf.d didn't exist, so i created it. now i'll reboot and see
rebooted. i saw only the desktop. so, i disabled compiz(control alt t for terminal and xfwm4 --replace)
but how to use compiz even without glx?
You meant xorg, right?
yes yes
I am not sure, actually... I have not really faced this issue before.
Why do you want to disable hardware acceleration.
firefox or brave run smoothly with hardware acceleration disabled.
but if i run, like, 2 brave tab, discord(no hardware acc.), and element(i can't disable it here), it lags, so much.
because 1 app is using hardware acc.
You should just disable acceleration in the browser, then.
Unmake that file you made earlier...
See if this works in Brave:
yes, but i need to disable it on apps that don't have this setting, such as element, spotify, so i'll keep it disabled and mark your post as solution...
Thanks!!
