Hi all.
I have a laptop running W11 on 1 SSD and Z17 on a 2nd SSD.
I have 2 wifi routers running as mesh with 3 SSDs connected to them for back up.
In the wifi console I made them as "media server" and when running W11 I can map them.
Now...my question...how can I map them in Z17?
Thank you
Does this help?
Thank you...but seems I am doing something wrong so far...
What this could be?
I ran
user@nameofPC:~$ sudo mkdir /mnt
[sudo] password for user:
user@nameofpc:~$ sudo mkdir /mnt/backup
user@nameofpc:~$ sudo apt install cifs-utils
Reading package lists... Done
keyutils
Suggested packages:
smbclient winbind
cifs-utils keyutils
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 146 kB of archives.
After this operation, 498 kB of additional disk space will be used.
Get:1 Index of /ubuntu jammy-updates/main amd64 cifs-utils amd64 2:6.14-1ubuntu0.1 [95,7 kB]
Get:2 Index of /ubuntu jammy/main amd64 keyutils amd64 1.6.1-2ubuntu3 [50,4 kB]
Fetched 146 kB in 2s (59,1 kB/s)
Selecting previously unselected package cifs-utils.
(Reading database ... 488868 files and directories currently installed.)
Preparing to unpack .../cifs-utils_2%3a6.14-1ubuntu0.1_amd64.deb ...
Unpacking cifs-utils (2:6.14-1ubuntu0.1) ...
Selecting previously unselected package keyutils.
Preparing to unpack .../keyutils_1.6.1-2ubuntu3_amd64.deb ...
Unpacking keyutils (1.6.1-2ubuntu3) ...
Setting up cifs-utils (2:6.14-1ubuntu0.1) ...
update-alternatives: using /usr/lib/x86_64-linux-gnu/cifs-utils/idmapwb.so to pr
ovide /etc/cifs-utils/idmap-plugin (idmap-plugin) in auto mode
Setting up keyutils (1.6.1-2ubuntu3) ...
user@nameofpc:~$ sudo mount.cifs //192.168.50.1/backup4TB /mnt/backup/ -o user=XXXXX,pass=PPPPPPPPP
mount error(22): Invalid argument
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
Password for root@//192.168.50.1/backup4TB:
Yes the password I entered is correct...
What am I doing wrong?
thank you
I would refer to the manual and dmesg logs as stated.
No other troubleshooting from what I posted...? Nothing evident in what I wrote that could explain this?
and how do I 'refer to the manual and dmesg log"....? I am absolutely not Linux expert
Done some delving. See if any of the later solutions on this thread (towards the bottom) resolve the issue:
basically the 3 SSDs I mentioned are physically connected to the Wifi routers.
I use Asus routers and the settings so far are "do not allow guest login" for the USB application in the Wifi admin console.
When connecting them on W11 I can map them by entering the same user/pwd used for the Wifi admin console.
does this help in troubleshooting this?
actually I have no idea I did this in root...as I wrote I am in no way linux specialist...I just followed instructions previously provided...
How can remove the mount point in root and create in home?
Thank you for all your inputs...however...can' t all these be "graphically be translated" as it should be for any supposed to be "Microsoft friendly basic user"....all what you wrote is totally beyond my comprehension.
