How Create Shortcuts on Desktop
Where is the 'Add Shortcut' option. Can't find it.
I supposed it should be possible in Zorin OS Pro Version 17.3.
Did I pay 47,99€ for incomplete software?
Problem resides from earlier versions and still not fixed.
What would you like to create a shortcut for?
Simply right-click a file and create a shortcut, move this shortcut e.g. to your desktop
First: this is not a common Function of the Gnome Desktop.
Here in Zorin, You have the Possibility to add Desktop Shortcuts in the Zorin Menu. You make a Right-Click on an application and there is an Option to add a Shortcut to the Desktop.
Besides that, there is a Gnome Extension that adds a ''Add to Desktop'' Function in the App Grid:
