I've seen people on Reddit do make Blur my Shell make apps semi-transparent. How do I do that?
I already have blur my shell, I just don't know how to use it to make apps semi-transparent. I don't know if I need to download an add-on from github, or something like that.
In BLur My Shell extension -> Settings --> Application tab
Note: You icons will also get semi transparent, so for me it's a no-no.
My options menu looks like this
It may be that it aren't supported in Gnome 3+
That would explain it. One of the time I saw blur my shell being used on apps was on a r/Unixporn post where the user was using Vanilla OS, which probably uses the newest gnome version.
