I deleted the direct access to Scribus from Main Menu (Graphics). How could I fix it again? I have in USR/Share/applications/Scribus.Desktop installed from Zorin Menu's Software but can not run it.
Please HELP!!
Please HELP!!
I would first try running in terminal:
sudo apt install --reinstall scribus
That should get things going...
In Main Manu app, click Graphics; then New Item
In the popup window,
Command: scribus %f
Comment: Scribus
Then click OK
SOLVED!. I just created a new element in "Main Menu" tool in "Sistem tools" and adressed it to usr/share/applications/scribus it Works!
Noted your suggestions too for next time. Thanks!!
Also I have readed anywhere that for puting a new access to a program on desktop, it can be made with the genome-tweak-tool.
For general knowledge!
