How I can create Hotspot point in Zorin
Hi Zorin family,
I want to share my laptop’s connection with other devices (Android,…).
In ubuntu I used to use a simple command in network settings,
In zorin I think it’s different,
plz help me.
Hi @gill, welcome to the forum!
You can create a Wi-Fi hotspot from your computer by following these steps:
  1. Open the Zorin menu → Settings → Wi-Fi
  2. Click on the ⋮ button in the top-right corner of the window
  3. Select the “Turn On Wi-Fi Hotspot…” option
    hotspot
  4. Follow the on-screen instructions to enable the Wi-Fi hotspot
Thanks @Azotin for replying, the problem is that I don’t have that option to turn on wifi-hotspot,I think it’s a hardware issue.
yes, I got the same too. I can’t make or turn on that feature
@gill - you have a typo (@AZotin instead of @AZorin)
@gill and @hafidirawans - could you please provide a screenshot of what options do show up for you on the Wi-Fi page when you click that button (column of dots as shown in AZorin’s pic).
btw I have lite version on my laptop right now.
Can you type xfce4-settings in your terminal (ctrl+alt+t) and let me know what shows up?
command not found
Can you click the “All Settings” button I saw in the first pic you posted and see if there are any Wi-fi settings? If you can’t find any then hopefully someone with Lite can help. I am using Core.
PS - @jgordon or @zabadabadoo - do either of you use Lite?
i can’t click that button. I’ll waiting for answers from lite users. Thank you so much for answer my question.
@carmar Alas no. Come back @Aravisian he was lite fantastic (pun intended).
I’m installing lite on an old PC and I’ll respond later.
Press the start button, settings, network connections.
Press the +, bottom left hand corner.
Choose connection type, select Wi-Fi and press create.
In Mode you can choose hotspot.
This documentation is for Mint but it uses XFCE like Zorin Lite does.
oh my god. it shows hotspot on that settings. Thank you so much :grin: :grin:
Marked solution. 32
Its portuguese (my native tongue) for "connect to an occult network" "turn on the WIFI point of acess" and "Unknow WIFI networks" i already tried the second option but it simply creates a new wifi network that doesn't work. How can i enable the hotspot? I already searched in the settings and in the "normal" places. Should i install some package?
