"sudo apt update"
"sudo apt upgrade"
"sudo apt install gnome-tweak-tool"
Create .icons folder
Create .themes folder
Extract the downloaded icons and themes to each folder as appropriate.
Zorin has the most tasteful icons. Except the trashcan icon is old. I replaced that.
