Welcome to the forum!
I assume this error is coming up when you're trying to install / uninstall something? This is just saying that something went wrong during an operation. If you run that command
sudo dpkg --configure -a
In a terminal, it should attempt to fix the errors, then you can run an update and upgrade and continue what you were trying to do from there.
