Hello. It is possible installing Zorin OS 16 Pro on external SSD?
Better use ISO and record on DVD or create bootable usb?
I want checked first if my all components in computer don't get some problems with drivers and black screen, what I have last version 15.3 Ultimate.
What kind software use(Rufus or Balena Etcher).
I have Radeon Amd R9 390 series. Find one subject where describe how to install if i get black screen(asked earlier)
Yes, you can install on an external SSD just fine.
You can use either USB or DVD. I personally find DVD to be a bit more reliable.
Highly recommend avoiding Balena and using Rufus, multiboot or Unetbootin.
