Hello.
Yesterday I downloading ISO from ZorinGroup server Zorin 16 Pro.
After installation on vm i get only Zorin login and nothing happening after that. Before it working without problems.
It is possible iso server image is broken?
After installation from iso in ther vm it stopped on this.
If it was working before and isn't after a new download of the .iso, I would also suspect the .iso download same as you.
Always, always, always test the iso SHA256 after a download. It takes only seconds and saves you hours of head scratching.
Ok. I download and check again ISO. Trying download and a get message network error. Trying again.
I used Brave webbrowser.
