I second this if you're doing manual partitions always separate out a /home partition I usually use a separate drive that's a dedicated /home partition.
Ok thanks. When i deleted swap partitions on Zorin then it started very slower on my pc. Zorin have situation or something after restart it repairing something automatic? Example back wayland and desktop things what was before deleted. Hmm also firefox start be more stable.
What it will be when i copy a folder Timeshift to new Zorin installation and then i put on place Timeshift? It is back all my settings with some date before my system is crashed?
I don't know 100% i don't use timeshift i'm not sure if that just restores personal files or if that will try and restore system files
I cleaned SSD with gparted. I don't know if wipe help better. Tomorrow i will doing all new. Trying finding all info here. In short installation creating partition. Installing first drivers, some software what need and propably it take some time. If i something missing feel free to put info.
