Hello Everyone
On my new laptop installing Zorin 17.3 and-for fun installed KDE-Plasma in terminal(I wrote sudo apt install kde-plasma-desktop),and when swich on kde-plasma,saw when all programs are there-I swich to Zoring Dekstop and how my suprised was then style File Managher Dolphin for KDE-Plasma move to Zorin Desktop...and i want to ask...how fix it?
I don't think you can. Is Files not showing at all on the Dash? (Panel)
In terminal, please run
sudo apt purge kde-desktop-full kde* plasma* kio* kwin* kwayland* breeze* konsole* kscreen* kinfocenter* hotkeys* krunner* kded*
Remove config files:
sudo rm -rf /usr/share/kde4 /usr/lib/x86_64-linux-gnu/kde* /usr/share/plasma /usr/share/kservices5 /usr/share/kservicetypes5 /usr/share/kxmlgui5 /usr/share/kwin
sudo rm -rf ~/.kde ~/.config/kde* ~/.local/share/kactivitymanagerd ~/.cache/plasma*
Restore defaults:
sudo apt install --reinstall zorin-os-desktop gdm3
sudo dpkg-reconfigure gdm3
Reboot.
Really, it is the left over Breeze packages that annoy us all.
Are but they style is KDE
Thank you for very fast anwer 0.0
Is there any way to install KDE so that it doesn't βeat upβ the Zorin desktop? I ask before I do from you anwser because in my time sphere is night and i going to sleep and i write anwser because i do't know how fast will be anwser tomorror so i wrote today
Thakny you for your very fast anwser again ![]()
Not really, no... it is because KDE is built with QT and Zorin Desktop is built with GTK.
It makes it very hard to define where to draw the lines of separation.
The better option - if you want both desktops, is to Dual Boot and choose which OS to use on a per need basis.
Or... to install only KDE Applications that you want individually, not the entire desktop.
I understood thakn you gor your anwser and help
i tomorror do it ![]()
I Wish the good day/night
Ok,i did it-just i don't wrie kde-desktop-full kscreen* and something else because wrote than system dosen't find this
I'm after reboot and...kde dosen't existic but style kde still in my main desktop zorin-os
I deleted some configure files kde in folder .config,again reinstall zorin-os-desktop used sudo apt reinstall zorin-os-desktop gmd3 and still folders are like kde
And i'm check and packages which system dosen't find are: hotkeys* and krunner*
And files which i delet in /.config are:
plasma-or.kde.plasma.desktop-appletsrc
plasma-locarsrc
Ok in zorrin apperance i reutrn to default setting and folders,file and libreoofice look like before
but Star menu and icons in right down side on my pulpot look like from kde
Ok i'm rebbot and all is like before
Thank you for help ![]()
