Oh. Yes, correct.
Could I make a copy of the folder on the Desktop and setup some software to sync the two? I think that would work for what I need.
I was wondering if there is a permission issue on the mount point. Z15 and Z16 should work the same in this regard.
But yes, your idea is a good idea, too- I use Megasync on Zorin, due to recommendations made on this forum. It works. I do not know if you can have the same folder syncing in two places as I have not tried- but it seems like it should be fine. Just have a Mega folder on zorin and a mega folder that leads to the same account on Windows.
It happens to the best of us, its a sign our body moves faster then our minds ability comprehend that movement.
Than you. I will try that and come back with the results once it's all set up.
Marked Solution. 338
