I have a created a custom layout for gnome how can i add it to zorin apperance for easy access
I don't think you can just add your own layout.
Since there are existing layouts and they are stored somewhere, I am reasonably sure it can be done. Since I do not regularly use Gnome and do not customize it, I am not sure how. But will look around and see if I find anything.
I don't recommend it, tho, make sure to try it in a virtual machine!
ok as @Kedric said i will try it on a vm
- Copy your theme files
- Run command in terminal:
sudo nautilus /usr/share/themes - Paste that copyed files there
- Open zorin appearane and change the theme.
oh not the theme i meant the whole layout
How do you mean whole layout?
He is asking how to display the layout like the windows 11 layout, normal windows layout and so
Ahhh, yes.
yeah thats exactly what i am asking
I remember in KDE you can do that. The problem I have with KDE is that its not as polish, and it has many bugs.
yeah i used kde for debian and the boot time was 2 minutes now in zorin with gnome its just under 30 seconds
Well my KDE neon boots fast. Even faster than zorin os core
it was the opposite for me idk why i tried it 2 times, same results were obtained
For me it was the same, maybe like a couple second difference but it doesn't matter
might be because you have an ssd or something i have a hdd
