After complete removal, you installed with
sudo apt install flameshot
And it won't launch?
exactly, I run the terminal install without any errors. flameshot is visible under "Graphics" and when I click nothing happens
In terminal, what does
flameshot configure
show?
How about
flameshot gui
Additionally:
This post says
SOLVED: I resolved this by resetting my locales (since my system wasn't able to locate LC_ALL) and desktop launch option. Go to:
System Settings > Regional Settings > Reset alland then set desktop launcher toExec=flameshot guiin/usr/share/applications/flameshot.desktop.
Might be worth trying, too.
flameshot config works well
flameshot gui - the screen begins to dance and changes resolution etc.
the steps out of that article I did not understand and I think I have to stop here for now. I will look into that again, hopefully with more success.
What I also noticed: installing via software as flatpack brings up another (newer?) version with different setup menu
I am at a loss. I would suggest contacting the Flameshot Developer on this one...
Flatpak can be seen as using the Rolling Release. So it is likely a latest release.
You might try installing the Flatpak version and see if it behaves properly.
