I am using zorin OS 15.3 lite. I am having two network connections one is external network adapter and another is the inbuilt one. Since the inbuilt one is causing problems I have been using the external network adapter and I want to disable the unused network connection so that it won't show up while I click the network icon.
I want to disable the intel PRP/Wireless 3945ABG and I am using the MediaTek 802.11nWLAN
While I was using windows there was a option to disable it but I can't find it here.
Any idea?
