Hello,
I cannot conect my Kindle 10th Generation to PC by using an USB cable. I have tried to do it several times.
Greetings,
jonatas.rocha
Hello,
Greetings,
jonatas.rocha
Whenever this has happened to me, I found that the cable was not the right type for Data Transfer. You might try switching to a different cable.
Aside from that, you may need a media transfer protocol tool
sudo apt install gmtp
Connect the device, then open gmtp and search for that device.
Thanks, @Aravisian,
I will try both solutions!
Hello, @Aravisian!
Finally, I have found a compatible USB cable. So I have connected my Kindle to PC and It was recgnized immediatelly!
Thank you so much!
Also second way is to use email address , and send what you need to your Kindle.
And opposite, from Kindle to PC ( for that you need to log on your Amazon acc on web, and than you can easily download all books to PC )
