Thank you.
So, since my laptop has a HDMI port, I should buy a HDMI to HDMI port?
And once connected, the option should appear by going to settings > display?
I could not fathom how you were going to be able to connect your Zorin laptop to your Zorin desktop using a HDMI cable, for the laptop to act as a second monitor for the desktop without some software.
Thank you, yeah it was the second option I was refering to
So, I think I would then need to buy a HDMI Dummy Plug Display.
This was the reason I asked whether there was a possibility to connect my laptop via cable or something else.
