Hello! I want to set this as my boot animation. So how do i create a PLymouth theme with it?
If you google create a plymouth theme you'll find tons of links in showing you how.
I wouldn't have come on the forum if I didnt do that already. Most of them involve knowing code
Correct, you're going to have to use some code if you want to create a theme.
Everything that a person wants to do requires knowing how to do it.
If you want to do it and do not know how... Then you must learn how. Life is all about learning.
Which... In my opinion, is the Best Part.
To add some perspective, the human brain storage capacity exceeds 2.5 Petabytes. Across several lifetimes, a person could never fill their brain to maximum capacity.
Marked solution. 179
