How to delete unnecessary files after system upgrades in Zorin 16.3?
Hello,
We have a Zorin 16.3 installed. Just recently the PC on which it is installed stopped working and I was afraid that the HDD went to silicon heaven.
Turns out, after technician had a look at it, that just Zorin had a loads of files (I suppose some old files after upgrades or plethora of logs) uncleaned and that totally filled up the HDD.
After he cleansed those, it is running fine.
I have four questions:
1.) How come system doesn´t clean these files by itself?
2.) What am I suppose to do to clean it - any command I can run?
3.) Can I set the system to clean those files periodically (once a month, for example)? If yes, how?
4.) Unrelated to the previous questions: is there any way to upgrade from 16.3 Lite to current 17.2 Core?
I always use Ubuntu Cleaner after any changes in any upgrades ...... usually once a week it is quick and easy ..... just remember to save at least 1 extra kernel in case of a disaster ..... I'll try and find a link to where to down load Ubuntu Cleaner ......
Here is a link to the site to download Ubuntu Cleaner .....
It also works on Zorin and I have used it for years thanks to Aravisian's recommendation year ago .....
Thanks, I will try it :slight_smile:
That should take care of question 2 and 3,
What about question 4? - Edit: Found my answer:
"If you’re using Zorin OS 16 Lite, you can upgrade directly to the Zorin OS 17 Lite series using the built-in Upgrade Zorin OS app."
Old kernels should be deleted by Software Updater, but you can simply clean out apt using
sudo apt clean
sudo apt-get autoremove
...but do read the output on screen from autoremove to make sure you understand what will be removed, before blindly hitting Y
Also cleaner apps use the same, so you should take care to understand what is being "cleaned".
Is it possible to set the system to clean those files automatically (ie to let those command be run by PC without me having to remember it)?
As I mentioned above, when you use Software Updater to update kernels, it should automatically remove oldest version after installing a new one. So that should be enough.
Automation of cleaning can put you at risk of deleting things that you should not delete. Hence my warning.
I use 'Stacer' to do that. But know and read what you are deleting.
You can install it from the Software center.
I will try the Stacer too, looks good.
