Hello. I've been trying to disable auto-dimming on Zorin OS 17. I've gone through all settings and can't find any that turn it off. I also followed the advice given in this thread:
Any help with this would be nice!
When You go to Settings>Power/Energy what Power Profile is active?
When I enter settings for power it is on 'balanced' mode
You can use a terminal command to set the idle-brightness to a custom value. If you don't like dimming set it to 100 [%].
gsettings set org.gnome.settings-daemon.plugins.power idle-brightness 100
You can also use dconf-editor to do this
sudo apt install dconf-editor
and then go to org> gnome > settings-daemon > plugins > power > idle-brightness
Maybe it also helps to disable "ambient-enabled" at the same power settings page.
When I enter the command it says there's no schema for
org.gnome.settings-deamon.plugins.power
I have the gnome extension, is there a different version of it that would allow me to change auto-dimming?
Did you write deamon or daemon? When there is a typo or there are too many . between the words it doesn't work.
Or are you on Zorin lite? Your profile is hidden so we can't see which OS you use.
I'm on pro. I retyped into the terminal and it accepted both idle-brightness 100 and idle-brightness false, but there's no change.
The problem is that whenever there's black spots, or darker colors on the screen, it automatically lowers the brightness. It happens for anything; videos, loading screens, pictures etc. it also darkens to the point that it's incredibly hard to see whatever is on screen. I know it isn't a problem with the monitor, as before it never did this prior to using Zorin, and is pretty old so it doesn't have any settings like auto-dimming.
And it did not help to set the ambient light sensor to off?
gsettings set org.gnome.settings-daemon.plugins.power ambient-enabled false
Logout and login again.
I read about this problem in Linux on old monitors, but haven't found a solution. If you have settings in your monitor for DCR or HDR you could try to play with them (enable/disable) for testing.
That sound for me more like a Thing of the Display itself to be honest. Is this a Monitor or the Display of a Laptop?
I'm using an old (not super old, but abt 10~ years old) samsung smart TV for the monitor. I've already gone through all of its settings, disabling and enabling things to no avail. I also didn't have this problem with the monitor before I switched to Zorin.
I've put in the command and reset a couple of times but there's been no change. I've run:
gsettings set org.gnome.settings-daemon.plugins.power idle-brightness false
gsettings set org.gnome.settings-daemon.plugins.power idle-dim false
gsettings set org.gnome.settings-daemon.plugins.power idle-dimming false
As well as variations with setting them to 0, 100, or false. I tested to see if these worked before and after restarting but there's been no change.
It may help to use the following guide to turn off autodim at Samsung monitors:
https://www.retrospace.net/infoseiten/readm.php?id=146
But I'm not an expert and I'm not sure whether it's worth trying for you.
This worked! Thank you so much, I've been trying to fix this for so long and thought i'd done all of the TV tricks. I can now see much better and there's no more darkening!!! Have a wonderful new year, and thank you again!! ![]()
You're welcome, thank you! A happy new year to you too! I'm glad it helped you solve the problem. That was a very hidden setting.
