I just connected my Zorin Laptop onto the network and it starts adding Printers automaticly.... We got about 400 printers here. How can I stop and disable this feature?
Hello @Roman78,
To prevent the Printer autodetect,
You can disable the process by opening the terminal and running:
sudo systemctl stop cups-browsed
and then
sudo systemctl disable cups-browsed
If you want, then you can re-enable it using:
sudo systemctl enable cups-browsed
and then:
sudo systemctl start cups-browsed
