I found a Gnome Extension that does exactly what @othiagosm wants, it's called Bluetooth battery indicator by [michalwanat].
Gnome Extension Page: Bluetooth battery indicator - GNOME Shell Extensions
GitHub Page: GitHub - MichalW/gnome-bluetooth-battery-indicator: Gnome-Shell extension displaying battery percentage for bluetooth devices
Two ways you can install extension:
Steps For The First Way:
Install the requirments:
sudo apt install bluez libbluetooth-dev python3-dev python3-bluez gnome-tweaksClone the repo:
git clone git@github.com:MichalW/gnome-bluetooth-battery-indicator.gitInit submodules:
git submodule update --initCopy to extensions:
cp -R gnome-bluetooth-battery-indicator ~/.local/share/gnome-shell/extensions/bluetooth-battery@michalw.github.comThe extension should work now!!!
OR
Steps For The Second way:
Install Gnome Tweaks and requirments:
sudo apt install gnome-tweaks
You can use theSoftware Centreto install these as well, just search for them and install them one by one.Open your browser of choice(eg. Firefox, Chromium, Vivaldi, .etc) and visit https://extensions.gnome.org/ it should prompt you to install an extension, install the extension.
Visit Bluetooth battery indicator - GNOME Shell Extensions then install the extension by clicking the on-off toggle
A pop out should come out and ask you do you want to install the extension, Click Install.
Result: A Icon should come out with percentage right of it.
Settings: This extension have settings, you can change the
refresh time, Devices, .etc
I hope this help, I realised that I don't really like the light theme because it burns my eyes. ![]()
