My laptop’s rather fragile button for the DVD drive broke a couple of years ago. Since then I’ve gotten used to ejecting it in windows file explorer via a simple right click.
Now I’m dual booting with Zorin, but cannot seem to figure out how to do the same.
I may well be missing something incredibly obvious.
Easier still - when you install CD/DVD you should get a notification top centre to open with files. Once in Nautius (if using Core), go to the triangle with line underneath, right-click and choose ‘Eject’.
