Hello, everyone!
I’d like to enable automatic login for a while, but I can’t do it directly to system settings. How can I enable auto login by command line?
Thank you so much,
Jônatas Rocha.
Hello, everyone!
Thank you so much,
Jônatas Rocha.
sudo nano /etc/gdm3/custom.conf
Remove the Comment (#)
What version of Zorin OS are you using?
Zorin OS 16 Core.
Please double check the command and path above. I think there must be a typo in your terminal command. I just checked this on two machines and the file is present on both.
You can also do this with GUI:
sudo -i
nautilus
Navigate to "Other Locations > Computer > /etc > /gdm3 then open custom.conf in Gedit Text Editor.
