How to enable gamemoded mode
Hello. I ran a gamemoded test in the terminal and unfortunately it ended with an error. Is there any way to improve the result by configuring the hardware settings?
:: Gamemoderun and reaper thread tests
...Waiting for child to quit...
...Waiting for reaper thread (reaper_frequency set to 5 seconds)...
:: Passed
:: Supervisor tests
:: Passed
:: Feature tests
::: Verifying CPU governor setting
ERROR: Governor was not set to performance (was actually powersave)!
::: Failed!
::: Verifying Scripts
::: Passed (no scripts configured to run)
::: Verifying GPU Optimisations
::: Passed (gpu optimisations not configured to run)
::: Verifying renice
::: Passed (no renice configured)
::: Verifying ioprio
::: Passed
ERROR: :: Failed!
: Tests Failed!
And this is my hardware configuration:
# Raport informacji o komputerze
## Szczegóły raportu
- **Data utworzenia:**                             2026-02-02 12:13:26
## Informacje o sprzęcie:
- **Model sprzętu:**                               HP HP Pavilion Gaming Laptop 15-cx0xxx
- **Pamięć:**                                      16,0 GiB
- **Procesor:**                                    Intel® Core™ i5-8300H × 8
- **Grafika:**                                     Intel® UHD Graphics 630
- **Grafika 1:**                                   NVIDIA GeForce GTX 1050 Ti
- **Pojemność dysku:**                             500,1 GB
## Informacje o oprogramowaniu:
- **Wersja oprogramowania sprzętowego:**           F.29
- **Nazwa systemu operacyjnego:**                  Zorin OS 18 Pro
- **Identyfikator systemu operacyjnego:**          (null)
- **Typ systemu operacyjnego:**                    64-bitowy
- **System okien:**                                X11
- **Wersja jądra:**                                Linux 6.14.0-37-generic
Thank you and best regards.
Have you tried to add your user to group gamemode? Then logout and login again.
sudo usermod -aG gamemode <yourusername>
Replace <yourusername> with your username, e.g.
sudo usermod -aG gamemode rashSE
I did as you wrote, but with no results. Maybe my laptop is just too weak and doesn't support it?
Make sure it's your nvidia card that is enable instead of the intel when running the test and when gaming.
sudo prime-select nvidia
Thank you very much! The test was a success :slight_smile:
: Loading config
Loading config file [/usr/share/gamemode/gamemode.ini]
: Running tests
:: Basic client tests
:: Passed
:: Dual client tests
gamemode request succeeded and is active
Quitting by request...
:: Passed
:: Passed
:: Supervisor tests
:: Passed
:: Feature tests
::: Passed
::: Passed
:: Passed
: All Tests Passed!
