Hey
So during my installation the pc had asked me weather I want to enable lock screen or not. At that time I had disabled that. How to enable Lock screen?
This may relate to your thread about screen blanking out...
Ohhh... I see. You selected auto log in. Yes, that is best avoided...
In the Zorin App menu, type users to search for Users & Groups
Launch Users & Groups and on your user account, look to the mid-right portion of the window. You should see "Password:" and to the right "Change".
Click change- then at the bottom of the PopOver Window, uncheck the box for "Don't ask for password on login".
Click OK
Thank you so much for your help
