Hi my friends
I'm using nemo file manager
I want to install more plugins
There is a problem
How to fix
Hi my friends
There is a problem
It's because it's aren't in the repositories, so I don't know if there's a fix.
Try
apt search nemo
to see if it's under another name.
aaoaa@aaoaa-HP-Notebook:~$ apt search nemo
Sorting... Done
Full Text Search... Done
ascii/jammy,jammy 3.18-5 amd64
interactive ASCII name and synonym chart
caja-owncloud/jammy,jammy,jammy,jammy 2.6.3.14058+dfsg-1 all
ownCloud integration for Caja
cdftools/jammy,jammy 4.0.0-1 amd64
Diagnostic tools for NEMO netCDF output
clamtk/jammy,jammy,jammy,jammy 6.07-1 all
graphical front-end for ClamAV
denemo/jammy,jammy 2.5.0-1build1 amd64
free graphical music notation editor (GTK front end to LilyPond)
denemo-data/jammy,jammy,jammy,jammy 2.5.0-1build1 all
data for Denemo
denemo-doc/jammy,jammy,jammy,jammy 2.5.0-1build1 all
documentation and examples for Denemo
fonts-denemo/jammy,jammy,jammy,jammy 2.5.0-1build1 all
music notation symbol fonts for Denemo
gir1.2-nemo-3.0/jammy,jammy 5.2.4-1 amd64
libraries for nemo components - gir bindings
golang-github-adrianmo-go-nmea-dev/jammy,jammy,jammy,jammy 1.4.0-1 all
Go library for the NMEA 0183 protocol
golang-github-nebulouslabs-entropy-mnemonics-dev/jammy,jammy,jammy,jammy 0.0~git20170316.0.7b01a64-1.1 all
Human readable entropy.
indi-aagcloudwatcher-ng/jammy,jammy 1.6+20220128183230-1 amd64
INDI driver for the AAG Cloud Watcher
letterize/jammy,jammy 1.4-2.1 amd64
phone digits to letter-mnemonics
libdata-dump-perl/jammy,jammy,jammy,jammy,now 1.25-1 all [installed,automatic]
Perl module to help dump data structures
libenum-perl/jammy,jammy,jammy,jammy 1.12-1 all
perl module for sets of ordered constants like enums in C
libmnemonicsetter-java/jammy,jammy,jammy,jammy 0.5-1.1 all
Java library for automatically setting Swing mnemonics
libnemo-extension-dev/jammy,jammy 5.2.4-1 amd64
Nemo component system facilities (development files)
libnemo-extension1/jammy,jammy,now 5.2.4-1 amd64 [installed,automatic]
libxbyak-dev/jammy,jammy 6.02-1 amd64
JIT assembler for x86(IA32), x64(AMD64, x86-64)
mnemosyne/jammy,jammy,jammy,jammy 2.8+ds1-2 all
spaced repetition flash-card program
nemo/jammy,jammy,now 5.2.4-1 amd64 [installed]
File manager and graphical shell for Cinnamon
nemo-data/jammy,jammy,jammy,jammy,now 5.2.4-1 all [installed,automatic]
File manager and graphical shell for Cinnamon (data files)
nemo-fileroller/jammy,jammy,now 5.2.0-2 amd64 [installed,automatic]
File Roller integration for Nemo
nemo-font-manager/jammy,jammy 0.8.8-1 amd64
Nemo extension for Font Manager
nemo-gtkhash/jammy,jammy 1.2-1build2 amd64
nemo extension for computing checksums and more using gtkhash
nemo-nextcloud/jammy,jammy,jammy,jammy 3.4.2-1ubuntu1 all
Nextcloud integration for Nemo
nemo-owncloud/jammy,jammy,jammy,jammy 2.6.3.14058+dfsg-1 all
ownCloud integration for Nemo
nemo-python/jammy,jammy 5.2.0-2 amd64
Python bindings for nemo components
pacpl/jammy,jammy,jammy,jammy 6.1.2-2 all
multi-purpose audio converter/ripper/tagger script
python3-mnemonic/jammy,jammy,jammy,jammy 0.19-1 all
Implementation of Bitcoin BIP-0039 (Python 3)
python3-nmea2/jammy,jammy,jammy,jammy 1.15.0-4 all
Python library for the NMEA 0183 protocol
qml-module-org-nemomobile-mpris/jammy,jammy 1.0.6-1ubuntu1 amd64
Qt 5 MPRIS interface and adaptor QML module
snooze/jammy,jammy 0.5-1 amd64
run a command at a particular time
syncthing-gtk/jammy,jammy,jammy,jammy 0.9.4.4+ds+git20220108+9023143f8b93-1 all
GTK3-based GUI and notification area icon for syncthing
uim-viqr/jammy,jammy,jammy,jammy 1:1.8.8-9build1 all
Universal Input Method - Vietnamese Quoted-Readable support metapackage
xscreensaver-data-extra/jammy,jammy 5.45+dfsg1-2ubuntu1 amd64
Extra screen saver modules for screensaver frontends
Nope, it's not in the repositories. Have you checked nemo, if it aren't builtin plugins?
Sorting... Done
data for Denemo
nemo-dropbox/jammy 4.6.0-0ubuntu2~jammy amd64
Dropbox integration for Nemo
nemo-preview/jammy,now 4.8.0-0ubuntu1~hirsute1 amd64 [installed]
Quick previewer for nemo
nemo-share/jammy 4.6.0+dfsg-0ubuntu1 amd64
Nemo extension to share folder using Samba
nemo-terminal/jammy,jammy 4.8.0-0ubuntu3 all
Nemo extension to enable an embedded terminal
You will need each of these packages as dependencies:
https://ftp5.gwdg.de/pub/linux/debian/mint/packages/pool/backport/x/xreader/gir1.2-xreader_3.8.5+victoria_amd64.deb
And finally, nemo-preview:
https://ftp5.gwdg.de/pub/linux/debian/mint/packages/pool/backport/n/nemo-preview/nemo-preview_5.8.0+victoria_amd64.deb
Since 17, Zorin OS defaults to Wayland which is incompatible with Nemo-preview and other components. You may need to log in on the Xorg Desktop for everything to work.
It seems that it is already installed. It stands in the Brackets.
That shows a Hirsute package... Zorin OS never was on Hirsute which is an intermediate release.
Then would be the Question how it can be installed.
And what should these Pictures let me know?
You are pulling from Mint Packages without the Mint repository added to your sources, so apt cannot access needed dependencies...
Here are those two:
https://ftp5.gwdg.de/pub/linux/debian/mint/packages/pool/backport/x/xreader/libxreaderview3_3.8.5+victoria_amd64.deb
Ah, now I see it! The ''victoria'' Add on the Version Number and the linuxmint Github Website.
Yes, though i am just using pkgs.org to look up the packages.
