How to fix x.509?
When is install zorin on my laptop it work after i restart it the screen only said integrity problem loading x.509 is it my laptop or my flash drive i have already turn off secure boot my laptop is a Aspire E 14 Acer
Did You disabled TPM, too?
Before You installed the System: Have You verified the Checksum of the Iso? What Program did You used to create the bootable USB Stick? Are You using a dual Boot System (Zorin+Windows)?
No i didn't dualboot i think i disable TPM it,s currently night so i will tell you in the morning thanks
But think it,s my usb i drop it on water ones but it,s still working
Then I would definitely use a different One.
But it still works i even installed win11 btw doi have to diable TPM
And which Program did You used for create the bootable USB Stick for Zorin?
I would try it with another Stick - only to test it.
What should i disable/enable
Thank for help it is finaly working
