i use x11 and stil not working any help?
Forpli
January 5, 2026, 6:13am
2
It is really difficult to install this program on Zorin 18 because there are many missing dependencies. Did you try to build it from source?
Maybe this github thread can help? But I'm not familar with this topic.
gamescope_4_Ubuntu24-04.md
# Build & install [gamescope](https://github.com/ValveSoftware/gamescope) for fresh-install Ubuntu 24.04 (Noble Numbat)
*[Due to what appears to be dependency issues](https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=1058493), the `gamescope` package isn't avalible for Ubuntu 24.04. So here's a guide on how to build and install gamescope for Ubuntu 24.04*
1. Pull latest git of [gamescope](https://github.com/ValveSoftware/gamescope)
`$ git clone https://github.com/ValveSoftware/gamescope.git`
2. Install needed dependencies to build `gamescope`
`$ sudo apt install libbenchmark1.8.3 libdisplay-info1 libevdev-dev libgav1-1 libgudev-1.0-dev libmtdev-dev libseat1 libstb0 libwacom-dev libxcb-ewmh2 libxcb-shape0-dev libxcb-xfixes0-dev libxmu-headers libyuv0 libx11-xcb-dev libxres-dev
libxmu-dev libseat-dev libinput-dev libxcb-composite0-dev libxcb-ewmh-dev libxcb-icccm4-dev libxcb-res0-dev libcap-dev
This file has been truncated. show original
CarlCP
January 5, 2026, 9:08am
3
Gamescope only works on Wayland by default, or on X11 if you have the right compositing setup. On plain X11 without compositing, it might not start at all. You could try switching to a Wayland session or installing the required packages for X11.
What have You already done to install it? What Instructions did You used? More Details would be good.
system
Closed
April 5, 2026, 11:45am
5
