I probably asked this before because I got rid of it before but I can't find the answer.
I reinstallled and I want to get rid of the 1st screen, the click here, slide up, yada yada, that you have to interact with so you can see the real lock screen you enter your password on.
My opinion, this is the most useless feature ever addded to an OS.
Zorin OS Lite and Core use a different display manager — terrible name as it just serves as the login screen — maybe there are some differences there. In Gnome (Core), you first have to select the user you want to login as:
