I have installed a plank, so it has a dock. don't need another one
show default dock when pressing the Windows key of my keyboard, it should plank dock. how do remove disable or hide this?
how do change the login theme too? I have several themes, and icons in the .themes and .icons folder in the home dir.
can anyone tell me a simple process for transforming to MacOSX like copying and pasting icons, and themes folders in the right dir? repeat for all os(optional)?
Did You take a Look in the Settings of Your installed Plank? I use Dash To Panel and there is an Option to deactivate the Dock in the Overview.
Put it in the home Directory is right. Another Option is to put it in the usr Directory. There You have an icons and themes Folder, too. There You can find the Zorin Stuff for Example. When You put it there a Theme or Icons are working systemwide and not only locally.
To configure the Login Screen is tricky on Gnome. You could try it with GDM-Settings (to find in the Software Store). there You can set up Themes and other Stuff for the Login Screen. Unfortunately it doesn't work realy good in my Experience.
[quote="Ponce-De-Leon, post:2, topic:37065"]
[/quote]Put it in the home Directory is right. Another Option is to put it in the usr Directory. There You have an icons and themes Folder, too. There You can find the Zorin Stuff for Example. When You put it there a Theme or Icons are working systemwide and not only locally.
cant copy to that folder
should copy both /home/ and /usr/share/themes or only one?
For the usr Directory You need sudo Rights because it is from the System. the easiest Way to use is the Terminal. A Command for this couls look like this:
No, only in one Directory please. When You put it in the one, delete it from the other.
You can make it, but ... I wouldn't recommend it. When You delete it and You go to Zorin Appearance and click there on the Accent Colors it would work because that depends on the Zorin Themes. That could be making Issues. So, I would say: Let the Zorin Themes where they are.
Thanks Leon. I have done and it works. But did remove plank and use default dash and it is not bad though. Now cant see the login theme look like mac, how to change it too?
That is a good Question. I have tried to change the Theme on the Login Screen too. But it never works. Like here written is GDM-Settings but it doesn't work good on Zorin.
