How to install mesa-amber driver and replace with the normal mesa driver
here my hardware information:
Mesa Intel(R) HD Graphics 2500 (IVB GT1)
00:02.0 VGA compatible controller: Intel Corporation 3rd Gen Core processor Graphics Controller (rev 09)
DeviceName: Onboard IGD
Subsystem: Holco Enterprise Co, Ltd/Shuttle Computer 3rd Gen Core processor Graphics Controller
Kernel driver in use: i915
(also i have mesa-utils installed)
So, this looks like it should I guess.
Maybe try it with disabled Hardware Acceleration. Or: Check if it is disabled and enable it.
Agreed.
@robloxiathineus, what about the terminal output for:
glxinfo | grep "OpenGL renderer"
the command identify my gpu, also i dont know how to disable hardware acceleration or enable acceleration, i just know than my gpu have no acceleration, i have this problem in all of the distros than i use my gpu just dont work.
That should be normally happen in the specific Program. In Brave, You can find that Option for Example or starting Brave from the Terminal with the Command
brave-browser --disable-gpu
to start Brave with disabled Hardware Acceleration.
nothing charges when i test this.
also this is my all my hardware info:
Caminho do hardware Dispositivo Classe Descrição
                              system         DC8CU41 (1700699)
/0 bus DC8CU41
/0/0 memory 64KiB BIOS
/0/3d memory 512KiB L2 cache
/0/3e memory 128KiB L1 cache
/0/3f memory 2MiB L3 cache
/0/40 memory 4GiB Memória do sistema
/0/40/0 memory 4GiB SODIMM DDR3 Síncrono 1600
/0/40/1 memory DIMMProject-Id-Version: lshwRep
/0/40/2 memory DIMMProject-Id-Version: lshwRep
/0/40/3 memory DIMMProject-Id-Version: lshwRep
/0/41 processor Intel(R) Celeron(R) CPU 1007U @
/0/100 bridge 3rd Gen Core processor DRAM Con
/0/100/2 /dev/fb0 display 3rd Gen Core processor Graphics
/0/100/16 communication 7 Series/C216 Chipset Family ME
/0/100/1a bus 7 Series/C216 Chipset Family US
/0/100/1a/1 usb1 bus EHCI Host Controller
/0/100/1a/1/1 bus Integrated Rate Matching Hub
/0/100/1a/1/1/1 multimedia HD Webcam
/0/100/1a/1/1/3 generic AVerMedia H823 USB Hybrid ISDB-
/0/100/1b card0 multimedia 7 Series/C216 Chipset Family Hi
/0/100/1b/0 input13 input HDA Intel PCH Mic
/0/100/1b/1 input14 input HDA Intel PCH Headphone
/0/100/1b/2 input15 input HDA Intel PCH HDMI/DP,pcm=3
/0/100/1c bridge 7 Series/C216 Chipset Family PC
/0/100/1c/0 wlp1s0 network RTL8188EE Wireless Network Adap
/0/100/1c.1 bridge 7 Series/C210 Series Chipset Fa
/0/100/1c.1/0 mmc0 bus SD/MMC Host Controller
/0/100/1c.1/0.2 generic Standard SD Host Controller
/0/100/1c.1/0.3 generic MS Host Controller
/0/100/1c.1/0.5 enp2s0f5 network JMC250 PCI Express Gigabit Ethe
/0/100/1c.2 bridge 7 Series/C210 Series Chipset Fa
/0/100/1c.3 bridge 7 Series/C216 Chipset Family PC
/0/100/1d bus 7 Series/C216 Chipset Family US
/0/100/1d/1 usb2 bus EHCI Host Controller
/0/100/1d/1/1 bus Integrated Rate Matching Hub
/0/100/1d/1/1/4 bus USB2.0 Hub
/0/100/1d/1/1/4/2 input5 input USB OPTICAL MOUSE Keyboard
/0/100/1d/1/1/4/3 input10 input USB USB Keyboard Mouse
/0/100/1f bridge NM70 Express Chipset LPC Contro
/0/100/1f/0 system PnP device PNP0c01
/0/100/1f/1 system PnP device PNP0c02
/0/100/1f/2 system PnP device PNP0b00
/0/100/1f/3 system PnP device PNP0c02
/0/100/1f/4 input PnP device PNP0303
/0/100/1f/5 system PnP device PNP0c02
/0/100/1f/6 system PnP device PNP0c01
/0/100/1f.2 scsi0 storage 7 Series Chipset Family 6-port
/0/100/1f.2/0 /dev/sda disk 500GB ST500LM012 HN-M5
/0/100/1f.2/0/1 volume 511MiB Windows FAT volume
/0/100/1f.2/0/2 /dev/sda2 volume 465GiB volume EXT4
/0/100/1f.2/1 /dev/cdrom disk DVDRAM GTA0N
/0/100/1f.3 bus 7 Series/C216 Chipset Family SM
/1 power To Be Filled By O.E.M.
/2 input0 input Power Button
/3 input1 input Sleep Button
/4 input12 input Video Bus
/5 input2 input Lid Switch
/6 input3 input Power Button
/7 input4 input AT Translated Set 2 keyboard
