how to install tableaue in zorin os
Tableaue does not appear to be available for Linux.
In the past, it seemed to get a good rating on Wine 4.3:
You may try using Wine:
sudo apt install -y zorin-windows-app-support
Once Zorin WIndows App Support (Wine 5) is installed, then run the Tableaue installer.
You probably want to read the Workarounds section here: WineHQ - Tableau 10.3.2 32-bit
if the installer doesn’t run well.
E: Unable to correct problems, you have held broken packages.
wine not install
sudo apt --fix-broken install
sudo dpkg --add -architecture i386 && sudo apt update
sudo apt install zorin-windows-app-support
again show thise problem
Does it list any other reasons or missing dependencies?
Marked Solution. 305
