Please advice on how to keep taskbar rounded theme without intellihide feature?
The option of getting rounded theme is conditionally under Panel Intellihide as shown below and hence disable Intellihide disables rounded theme; Gnome-tweaks doesn't help at all.
Disable floating round theme
Edit: when you change to disabled, then back out & also disable hibernation if you dont what hibernation, it will keep the floating round theme disabled.
Do you want to disable Intellihide Panel because there are one or more of its options that you don't like? Maybe options that make the taskbar hide? Is this that you meant?
@Ocka I want to keep rounded theme enabled and disable only autohide.
@Luca_Pavan yes, I want to disable Intellihide only cause interference with such controls of opened apps sharing the same position with the taskbar
I tried the 3 options available below, but the same behavior remains,
All Windows
Focused Windows
Maximized Windows
@Aravisian Thanks for your good idea; It should hmm partially works but;
I checked out the gnome-shell.css parameters and changing border-radius have no effect as well.
I think CSS only is not enough cause the operation consists of two things, rounded radius and shifting panel to new coordinates (x,y) and no clue about that shift in CSS parameters.
Glad to hear you fixed the issue.
Could you please 'Mark' the post that helped as "Solution".
Or add a post explaining your Solution.
This lets Others know they can find a solution here that may help them.
No it doesn't in the Customisation section. I have moved the thread to General Help. You should find a Solution checkbox under the applicable post now. Click on the "..." (three dots).
I see this post was on Customization section, not on General Help, so couldn't be there Mark as Solution. But now that's on General Help it should be available.
