I have seen some users on the forum asking for a "Minimal install" option, similar to how Ubuntu has it, and decided to put it upon myself to deliver that.
I've also seen some say that "Only the Pro version has this!"
this is not true, the Pro version's "Minimal" leaves out all the pro software, essentially just doing an installation of Zorin Core
This procedure is quite easy to do, it's really just removing some programs using the following command:
sudo apt remove -y --auto-remove gnome-{sudoku,mines,mahjongg,maps,sound-recorder,todo,weather} *quadrapassel* aisleriot brasero remmina gimp *libreoffice* evolution rhythmbox pitivi cheese
Though, do note that this is just what I think a Minimal install would look like, be sure to leave a comment/reply to this and let me know what you think I should add/remove etc. ![]()
