How to modify Places indicator
Hello guys,
Since I have added my mounted devices to the favorites section in Nautilus, I need to modify Places indicator device section and remove that.
I am not familiar to JS, but I think it's possible to remove this section
Thanks.
Did You made a right-click on it and look if there is a Menu-Point to remove it?
It needs a hard code modifying to remove this section, it's not that easy to remove devices from this extension. I checked out the codes but I didn't understand
I found the solution, actually it was easy, I didn't read the all codes since I am lazy.
I just remove the 'devices' variable from the JS file.
Now it's OK
