Hello,
Well, I’m in the process of doing my first Backup.
I’ve just bought an external SDD SSD but it does not appear in my other locations.
I’d like it to appear when I use Deja Dup.
How can I make it to appear there?
Hello,
Is that SSD? You didn’t by an HDD? Not sure if this is the issue as we don’t have enough information:
Yes, SSD because I wanted something for my laptop and my desktop, and to be small, quiet and convenient to travel with.
Your link provided does indeed not show any answer.
I run lsblk and it seems that my external hard-drive is there:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 232,9G 0 disk
└─sda1 8:1 0 232,9G 0 part /
sdb 8:16 0 223,6G 0 disk
sr0 11:0 1 1024M 0 rom
Now it does appear.
I did:
Zorin > Disks > My External Hard Drive was there but not mounted
Then,
I clicked on the icon "Additional partition options" > Format Partition > I checked "Internal disk for use with Linux systems only".
I waited for around 90 minutes.
After,
Zorin > Files > My external Hard Drive was there, and when I clicked on it, it mounted ![]()
Same issue here. But I was using a different way to solve this, same result
Here are the steps of how I mount an external SSD on Zorin:
After following these steps (refer full manual here), the external SSD should be mounted and accessible in the selected folder. If you encounter any issues, such as the drive not appearing or not being accessible, there may be other factors at play, such as driver compatibility or file system format.
