Allow to mount ISO files as a disk, like in Windows in Right click menu on .ISO files.
I notice that Zorin only uses parts of Gnome not all of it - if I try to install the full Gnome I get held/broken packages but running checks in the terminal yields no results. On a full-gnome blown desktop it would be possible:
After you’ve read swarf’s link, you can also consider GCDEmu: https://cdemu.sourceforge.io/project/#sf
To install, using terminal:
sudo add-apt-repository ppa:cdemu/ppa
sudo apt-get update
sudo apt-get install gcdemu cdemu-client
@carmar D’OH! Totally forgot about that - that’s what I used when I was playing Homeworld on Zorin!
