I am new to Linux and need some help if possible, I have 4 partitions set up and want to install another OS on Partition SDB4. I split the drive into 4 partitions. For now it will not nor do I have knowledge to mount part 4. What is the best format type to use on a clean partition etc. Used Gpart to resize so that part 4 will exist. Any help will be great
Hello there! The best way to mount partitions or drives, is via the DISKS utility.
Click the Zorin
logo bottom of screen, type disks, click on that to open DISKS.
On the left side of the window is your physical drives list. Choose the one in question. On the right side of the window, shows all the available partitions on the drive.
Click the gear
icon, click EDIT MOUNT PARTITION.
Make sure to put a checkmark in AUTO mount at boot, and SHOW in system interface. Keep in mind, you can also manually mount partitions, via the Play
icon as well in the previous window.
Before I install an OS, I always start with an EXT4 partition. Then when I go to install an OS, I let the installer do what it needs to do an auto install from that point fourth. Hope this helps!
StarTreker
Your Tech Support Guru
As long as SHOW IN INTERFACE is checked, then yes, he could do that in his file manager.
Marked solution. 232
