[How To] PulseAudio Bitrate & SampleRate - PRO Tip
PulseAudio is an outdated but still used audio server component, that leaves a lot to be desired. It really could use a lot of improvements, but Linux still uses it. Depending on your needs, you are going to run into some issues, and I would like to provide a PRO-TIP, that will greatly help out users out there.
Not only am I a computer nerd, but I am also a bit of an audiophile as well. While internal computer sound cards are much improved over the old designs, you are still requiring resources from your computer's CPU, to process the sound, which eats into your gaming performance.
I personally love external USB DAC's, (Digital Audio Converter) as you place all the sound processing on the DAC's chip, thus freeing up resources for your computer's CPU. The problem is, PulseAudio defaults to a 16-bitrate and a 44100-Hertz sampling rate.
PulseAudio, due to its bad design, has none of the config options in the GUI that actually matters, and it requires editing the config file, to make those changes. To increase your bitrate and sample rate, navigate to...
etc/pulse/daemon.conf
Now, open the Daemon.conf file as administrator.
Scroll all the way to the bottom, and you will find the sample bitrate format, as well as the default and alternate sample rates. If you simply change these values and save the config file, you will notice that the changes never stick.
This issue was the bane of my existence, until I discovered, that I need to commit out the semi-colones! So make sure to delete the semi-colones, for each config change you make. Then once you save the config file, then you can reboot your system.
Or, if you wanna be a pro, you could simply restart the PulseAudio server, using this command in terminal!
systemctl --user restart pulseaudio
If you have a DAC that has a screen, it will confirm the choice you made, to show the changes.
S.M.S.L M200 DAC
So, with that said, hopefully this prevents many other's from having to pull their hair out, wondering what is going on, why their changes aren't sticking.
Will this boost volume too, in windows when i had the sound at 40-45% i had good sound out of my laptop. In linux i need to set it to 80-90% to achieve the same, in games the volume sounds needs to be set around 110% for the sound i want (in windows i used 50-60%). Most of the time i game with my airpods on, but sometimes i want to play without airpods. I can achieve the same sound, only in linux it requires more %
Hello Michel, welcome back! :grin:
In regards to volumes coming from your computer directly, you can set them more detailed, via the Pulse Volume Control App, instead of using the system tray...
As you can see, I keep my volume at 100%
Piece of advice, don't exceed 100% in here, because the minute you start boosting the volume above it, you invite distortion.
The cool thing about my DAC, is that it has volume control built in, you can raise and lower the volume as needed, it has a pre-amp inside. This unit is made to work in conjunction with my S.M.S.L SP200 headphone amplifier, and that thing can produce serious volume amplification.
This is my SP200 AMP, which I modified with a golden aluminum volume knob.
This AMP provides up to 6-watts per channel into 16-ohms, which is plenty of power, even for really large headphones, like my Denon AH-D9200's.
Best headphones I ever bought! And that is the silver core stock cable you see in the picture. It wasn't long after, that I got a nice hand made copper core cable from ForzaAudioworks.
Looks good, feels good, sounds good.
You know, I only recently discovered that Pulse Audio is the 'de facto' audio software used in the automotive industry in respect of automobiles audio installations! I still prefer ALSA, even if Pulse Audio can't be removed!:
I am wondering if this should be filed in the "Tutorials" section. Discuss. Zab.
To be honest, I completely forgot about that section, as the last time I posted there, or looked in there, was like 2021. I'd be all for the moving of it, to the proper section.
EDIT: I just moved my thread, first time I've done a thread move, also since 2021. Yeah, I kind of fell off the face of the map for awhile there lol.
@StarTreker do you know the program "Firmware". If i am not wrong you tried to update firmware in the past using wine. This application will correctly flash the firmware of devices.
What a wonderful Christmas gift @anon96359095 , this is exactly what I've been looking for, thank you!
Edit: Good news, I found and installed the app from the software store just fine, and it appears to see all of my devices, including even my USB connected S.M.S.L M200 DAC. The bad news, there is no firmware release available for everything in the list, including the mobo.
FYI, the version I installed that was in the software store, is version...
I do like how the APP can see all the devices, not even HardInfo is that good! But HardInfo is no longer updated software, and is literally years out of date, it can't even see M.2-NVME drives, so that just tells you how old that APP is lol.
PS: Yes, I did click on update outdated meta data, and it appears to be outdated everytime I launch the APP, and I have to keep redoing it. Not sure what the deal is, or if the APP is kept updated or not. Anyways, thanks again, I appreciate it.
Merry Christmas my friend :sunglasses:
